I think that means that the hfe is really, really low - I could be wrong, though. I'd clean each transistor leg with alcohol and try again, just in case. Re-read entry #5 at the beginning of this thread too - lots of great info.
The TC-1 is useful, but outside of pinout I don't really use it for transistors, Ge or Si. I've found hfe readings for Si to be way higher than expected, and that's likely due to the test current; using a Peak DCA55 or RG Keen setup resulted in data that hews closer to both the datasheet and what I would expect certain transistors to be.
TC-1's Ge hfe/leak readings can be close enough to what Keen & Peak say (great comedy duo, btw), but mostly for lower-gain devices. It's pretty easy to set up a simple RG Keen tester, and I found it to be miles better than the TC-1 for hfe. The DCA55 is excellent, though.
Quick note - I also wouldn't count on the TC-1 OR the DCA55's Vf readings for Ge diodes, either - maybe Si too. They're WAY higher than simply checking with a multimeter, and lie far beyond what you'd expect - again, likely due to test conditions. You might buy Ge diodes that have a certain low Vf claim, then test them on a TC-1 and feel burned since they can read more than 50% higher than on a simple multimeter.
For me, the TC-1 shines for resistor and capacitor ballpark, transistor NPN/PNP/pinout, and LED testing/pinout.
