Tonebender mki stripboard
Johnnyorange500
Hi,
I stupidly counted the measurements wrong for my tone bender mki strip-board. And cut it by x8 instead of x9. And followed this layout. So the ailments are going to be a little off. I’ve tried to compensate for this..I’ve not committed to soldering it yet., am I best recutting another stripboard. Or is there a way around this.
Cheers
Johnny
Solution
I've always wanted to know two things about the MKI: Did you just twirl the leads together and solder them? And how is the board attached to the pots?
Yep pal. Exactly that.
It’s held by the soldered parts that join onto the lugs of the tone pots. I did wonder the same but once it was in front of me and i got stuck into the build it all makes sense.
Solution
