9 out of 10 doctors prescribe ring mod for boring people
Pretty sure R17 needs to connect to pin 2 of the op amp
You loan 10 people a ring mod and 9 out of them leave it gathering dust in the box.show me one non boring use of ring mod from 9 out of 10 people, doc
Pretty sure R17 needs to connect to pin 2 of the op amp![]()
still need someone to show me how to mod that slide switch to a stomp switch... lol I'm not smart enough to know how to do it..
I'd imagine it would need to be pulled out for the mod.... which is fine too.... I could always make a dummy slider to close it upThat's easy enough, but what would you do with the slide switch?
It'd need to be disconnected (unless we get fancy with relays and stuff)... would you just leave it inactive?
perfect spot to put in a presence control and ditch the trimmer.I'd imagine it would need to be pulled out for the mod.... which is fine too.... I could always make a dummy slider to close it up
Yeah this was my thinking as well, remove the slider and wire up a pot for the presence trimmer in that spot, add a stomp for the channel switching.perfect spot to put in a presence control and ditch the trimmer.
