Yup, definitely check for stuff like that. In normal operating conditions the MOSFET shouldn't be getting very hot, nor should any of the components really. I mean the tubes will get warm, but you know what I mean.My Ambassador Mosfet got real hot when I first plugged it in, no sound & it was a bit of solder debri between 2 pins on the back solder side!
But... But... LM308...Glad you got it sorted out. hope the audio is all set too. I tried all the different IC's (Motorola LM308H, LM308N, OP07, NE5534 and AS301AH) I had on hand last night in my regular rat. After testing them all, I decided to go with the AS301AH for the lab rat. All the ICs sounded almost identical. But the AS301AH sounded a little better to me.
THAT's what I'm talkin about!!! Team 301 all the way baby!Glad you got it sorted out. hope the audio is all set too. I tried all the different IC's (Motorola LM308H, LM308N, OP07, NE5534 and AS301AH) I had on hand last night in my regular rat. After testing them all, I decided to go with the AS301AH for the lab rat. All the ICs sounded almost identical. But the AS301AH sounded a little better to me.
Yup, exactly that.If I wanted to try assymetrical clipping in the lab rat, would it work I put two 4148s in series in one of the sockets and then an LED in the other?
That's how knowledge comes, piece at a time through experience.Nice! I am starting to understand these things!
No issues with the audio working properly. I went through my IC inventory and settled for now on using an OP07 just because it was the quietest one in the bunch. I think my LM308 (not metal can) was the runner up. I may try a couple of the "standard" mods to take C5 and R8 out out of the circuit and try a different cap value for C8.I have the power section of the Lab Rat running and will get things back in the enclosure before checking the audio. Replacing the UF4007 solved the problem. Of course I only got there after replacing several other parts that did not fix the problem. The diode I took out looked OK on the board and seems OK with my meter after I pulled it, but it was the weak link.
That is two boards where I had defective parts that were a pain to troubleshoot -- the diode here and a bad inductor in a recent Black Eye build. The saving grace is that the parts count on these boards is pretty low so it makes it easier to sort things out.
Do you have a Picture of your Lab Rat Build?THAT's what I'm talkin about!!! Team 301 all the way baby!
