herliplex
Running into an issue when using the intelligent relay bypass with the parenthesis mini for the boost side.
1. No signal goes through when the relay is bypassed.
2. Noticing a bit of signal drop when the bypass is being used.
I pulled out the two apart, and everything works as expected on the parenthesis mini when not using the relay switch. So I isolated the issue to the relay bypass, you can see the issues persist in the video below.
Anyone else bumped into this before?
