Extending my previous comment. I think such kind of a non-programmable switcher would be great to have in a smaller form-factor. It can be really handy in cases when someone wants to combine 2 or 3 different effects in one enclosure.If you end up with a non-programmable switcher it would be really good to have 2 different switching modes:
"and" - like a normal bypass when you can have multiple loops engaged at a time
"or"- only one loop can be engaged at a time, so when you engage some loop all other loops will be disengaged.
Not that I’m opposed to building several varieties of switchers (or anything else, it would seem), but knowing what some of the other upcoming options might be would certainly be great. I know it’s still early in the process, and your starting this thread as an organizing one for the possible line of switchers is great.I'm not opposed to multiple projects, in fact I'm planning on it.
I do want to do some Arduino projects as well, so it's certainly not out of the question.
Working up a design now for a fully passive 3PDT based version.
My calculations are that for 100% mechanical routing and switching one would need:I want to see how they're handling the effects order switching...
I drew up a relay matrix a while back that could do it, but it involved a lot of relays.
I suppose you could combine solid state routing along with mechanical relays to swap order while maintaining true-bypass without 50 relays...
I'm wondering if they're using a combination of mechanical and solid state switching...
Relays to bypass, but solid state switching to route the order when a loop is active. That'd still technically be true bypass ...
I might have to crack one open just to see...
I’ve also seen MXR/DOD style SPDT “output bypass” switching (where the input is always connected) called “true bypass” since it used a click switch.True by pass implies no buffers, but a direct cable from input to output, when the effect is off.
That said, it would not surprise me if marketing would coin the term even when it does not apply. (there has been Class AB amps marketed as Class A, because of the term "Class A" thought to mean higher quality than B or AB)
You mean like when all the effects are off? One effect off still means to route the signal from the effect before to the effect after. It still goes through the routing.Right, what I'm suggesting is additional solid state switching when the effect is on.
The hiccup there is that the copy makes a point to discuss the switchable input/output buffers. Any transistor switch will amount to a buffer of sorts.True-bypass doesn't necessarily mean "True-active".
