SHO 'nuff!
What if you did that steel wool and vinegar process to antique it then a clear coat to preserve it, I'd change my vote!
In Accordance with Prophesy, I am leaving the box bare. I hit it with a little Scotchbrite here and there to remove some JB Weld fingerprints. Other than that, it's au naturel. Got another Handy Box pedal in the works, but right now it's still in the breadboard testing phase.
LOL.
It's a metal box used to install light switches and outlets in the walls of your house. Normally, you punch out one or more of the circular cuts and run wires thru the holes. These days, a lot of builders use shitty plastic boxes because they are cheap.
I get mine here:
https://www.lowes.com/pd/RACO-1-Gan...ard-Handy-Ceiling-Wall-Electrical-Box/1098497
You won't find a cheaper or sturdier pedal box!
Here's one in my attic, used for the "normal" use.
