Check AliExpress if shipping from mainland China is cheap for you.
Cheap extractors to be had or if you want to diy, as I did, you can buy a large sheet of the the activated carbon filter material for a few bucks.
I use a repurposed equipment cabinet fan(19 wide with 3 large 120v fans) that I acquired from work. It's wired to a switched powerstrip that turns both the fan and my iron on. Helps me not forget to turn the fan on and not forget to turn the iron off.
