hamerfan
I recently watched a youtube vid of an electronic engineer and hobby guitarist. He did a pedal kit from musikding with a to me strange soldering technique.
He stuck the parts thru the holes as usual but fixed them with a small soldering points on the parts side. He did that with all resistors and diodes in one turn and then he flipped the board. He cut all sticking out leads first and soldered them full. Then with the bigger parts in the same way.
I know, there are many ways to skin a cat, but here you have the double amount of solder points. Whats the reason to do it this way? May the double sided solder points have a better connection? Does look cleaner on the solder side without the bended legs? I read somewhere that there is a chance that the solder joint could break if you cut the leads after soldering as most of us do it.
