Paradox916
Has anyone used the Duo-phase in a stereo application? Or is everyone running one into the other? If you have used it in stereo how’s the synced and inverted phase sound? Hows the width?
Right on…. standing by.I'll give it a shot tonight.
Did you read through this?
Duo-Phase
Haven't had a chance to record a demo, but I can assure you it does a thing. Audibly, even. I'll try to get a video tomorrow before I leave, or when I get back in a couple days. I included my build doc notes for the things I changed. Changes apply to both sides All the 3.9k, 39k, and 390k...forum.pedalpcb.com
I built mine standard. I was excited to try this just because I have a couple amps plugged up right now and I've been messing with some stereo stuff, but now that I'm thinking about it, I don't think the duophase is really set up for Stereo by default.
One in, one out : Yes
Two in, two out : Yes
One in, two out: Nope
I could run a pedal with stereo outs into the two sides and run the two sides out to the amps, but that's just running two totally independent phasers. If I understand @DGWVI 's mod, his would let you run one in, two out with them synced, but split them to two channels which sounds like it could be cool.
This is what I was curious about, I get its like running two phasers in parallel but the LFOs are slaved to each other and can be put out of phase correct? I was wondering if anyone has tried it. If one side “phases out” while the other “phases in” that would be the hope, even if I had to dial each side in manually would be ok but as a summed mono signal I have no interest in that. But now that I think about it building another Binaura might actually be cheaper and I could probably program exactly what I want.Did you read through this?
Duo-Phase
If you have the Sync switch engaged then Side A's LFO takes control of Side B, and then engaging the reverse switch will invert Side B's sweep while keeping it in tempo with Side A.This is what I was curious about, I get its like running two phasers in parallel but the LFOs are slaved to each other and can be put out of phase correct? I was wondering if anyone has tried it. If one side “phases out” while the other “phases in” that would be the hope, even if I had to dial each side in manually would be ok but as a summed mono signal I have no interest in that. But now that I think about it building another Binaura might actually be cheaper and I could probably program exactly what I want.
YES! This answers one of my big questions thank you. Now someone put some headphones on and tell us how it sounds. the phase II I built I really liked so this is starting to sound promising.If you have the Sync switch engaged then Side A's LFO takes control of Side B, and then engaging the reverse switch will invert Side B's sweep while keeping it in tempo with Side A.
Sounds great. I don’t think I’d buy a Duophase just to be able to get that stereo sound, but if you’ve already got one I’d say it’s definitely worth playing with.how’s the phaser sound in stereo?
Okay - this is a weird rig
Two independent signal paths is true stereo.
It's all about how you wire it up.
Mono in, stereo out.
Stereo in, stereo out.
Mono in, pseudo-stereo out (Left from one channel, Right from the series combination of both channels)
Nothing is forced by the PCB itself, you can wire it up to do whatever you want.
And yep, the LFOs can be linked and one inverted so one side is sweeping up while the other is sweeping down.
Or you could do it with the Binaura if you wanted:
I would think by now you know me well enough no PCB is going to put me in a boxNothing is forced by the PCB itself, you can wire it up to do whatever you want
… stereo is kind of like shredding… it’s auditory masturbation, no one else wants to hear itEntirely my opinion, but I think stereo phasing is more impressive through headphones, not so much through actual amps in the room.
HA! Sure do. Good catch.
Here's the view facing the other way.
Why you gotta be holding out on these stereo patches!Since we're talking stereo, and I plug this thing every few months when I see the chance....
(And it was the next clip that loaded after the roto thing)
