swelchy
Total noob..... I've tried 3 pcbs of the kliche with failure everytime. My current build allows bypass signal to pass through pedal when engaged or not engaged the signal passes and makes no difference in sound..... LED light comes on..... Turning any of the pots creates no difference when turned either direction... it's like the guitar signal just goes around the effect... I'm using the kliche breakout board for ease of wiring.... I dont get it... I measured every component with my little transistor tester before soldering... Every single part besides the IC's and those came from Tayda and should be fine right? I checked religiously for solder bridges... I have protective caps on the back of the pots.... I'm ready to just give up... I built a pedalpcb rat clone last week from start to finish in one sitting... threw it in the enclosure and it was perfect first time and that was my first pedal i've ever got to funstion so far. So far ive thrown away a timmy builfd, a fuzz face build and now about to toss three klons in the garbage.
